anchortown
#1 Posted : Saturday, August 23, 2008 9:38:45 AM(UTC)
anchortown
The unit will run and freeze OK. The next day it thaws. What should I do?
libertyappl
#2 Posted : Saturday, August 23, 2008 10:46:49 AM(UTC)
libertyappl
Can you be a little more descriptive as to how long it runs, then starts thawing, and so forth.
Nat
anchortown
#3 Posted : Sunday, August 24, 2008 4:52:46 AM(UTC)
anchortown
Yes it will work OK for one day and then the next day it will warm and not work.
#4 Posted : Sunday, August 24, 2008 11:06:22 AM(UTC)
When it fails, try to find out what is working/not working? Any light bulbs working? Fans turning?
anchortown
#5 Posted : Monday, August 25, 2008 6:39:50 PM(UTC)
anchortown
Thanks. The inside light comes on but the fan or compressor will not run. For a while it would cool one day and then warm the next. There are two connections at the compressor. One is an overload and the other is a relay. How do I check them to see if they have power? Spent $45.00 today for tech to tell me its the compressor thats bad. He put a jumper on the controls inside the refrig and stated that it was the compressor that is bad. Told me it would cost more to replace compressor than a new refrig would cost. Even wrote up the bill saying recent storm caused low power and burned up compressor. What now?
libertyappl
#6 Posted : Monday, August 25, 2008 6:59:13 PM(UTC)
libertyappl
I've never heard of anyone "putting a jumper on the controls"
Sounds more like it's stuck in defrost with no fans running. But to check the compressor:
Get an ohm meter, set to lowest ohms and zero the meter, remove one wire at a time and label it according to the terminal on the compressor. touch one to the common (C) terminal and the other probe ti the run (M)terminal, should read between 1-10 ohms. if not the compressor is bad.
let me know and we can check something else if need be.
Nat
anchortown
#7 Posted : Tuesday, August 26, 2008 9:05:45 AM(UTC)
anchortown
Checked it as you stated. The compressor is now running and it cooled. Will wait for 24 hrs and check it again. Thanks
libertyappl
#8 Posted : Tuesday, August 26, 2008 9:11:10 AM(UTC)
libertyappl
keep us posted
anchortown
#9 Posted : Thursday, August 28, 2008 5:21:23 PM(UTC)
anchortown
Lasted being cold a few hours. Now will not run at all.
Guest (8)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
