Davey J
#1 Posted : Monday, December 6, 2010 7:44:25 AM(UTC)
Davey J
Maytag ( Magic Chef ) Model MTB1895AEB fridge . Have only 30 deg (f) at lowest setting on Top Freezer , even after letting set 24 hrs after temp. setting changed. Removed lower rear tin and cleaned dust from all visible components,including in and around coil on rh side, made no difference.Fan in upper section does run.Lower ( refrigerator ) section cools to around 45 deg (f) .Wonder if I have a parts issue here,or should I be looking for a new fridge.
Joe / APP Team
#2 Posted : Monday, December 6, 2010 11:29:09 AM(UTC)
Joe / APP Team
Dave,
Look at the freezer back wall,
If there is frost, snow or ice on the back wall you most likely have a defrost problem.
Even so, remove the freezer back wall and visually inspect the frost on the evaporator coils, it should be a nice even coat of frost on the whole assembly, no vacant spots or heavy build up in one area.
If all OK,
From there you will need to remove the control panel assembly from the ceiling in the refrigerator compartment,
Check the styrofoam block in the damper assembly for ice and debris, in the air direction tunnels all the way through to the exit port blowing the air on the temperature control capillary tube on the side of the panel.
Also check that the temperature mass barrel is lined up and in the proper position in the holder on the side of the panel, and the air is being directed onto the barrel.
If all the above checks are proper, suspect a bad temperature control.
Davey J
#3 Posted : Tuesday, December 7, 2010 10:49:21 AM(UTC)
Davey J
Thanks,did as you suggested. Found buidt up of frost/ice on one of the lines to the evaporator coil,no frost/ice on the coil at all. Fan motor runs all the time as well. Unplugged fridge,let it manually defrost and dry. Did remove temp control panel assembly,found no ice or frost in any areas there,and damper assembly moves freely. Thought mabye the evaporator coil ice was the problem,so this am I replaced back cover in freezer,set both controls to 5 and plugged in fridge. Fan contiues to run in freezer,temp really not coming up much,now 55 in fridge,about the same in freezer. Temp control,or repairman? Thanks...
Joe / APP Team
#4 Posted : Tuesday, December 7, 2010 1:39:40 PM(UTC)
Joe / APP Team
Davey,
Bad News, based on your description of frost on the evaporator coil assembly.
You have a Restriction in the refrigerant lines,
Unless you're a refrigerator or A/C technician, you wont have the special tools and refrigerant,or meters to repair your refrigerator.
I imagine it would be a pretty expensive repair, you may want to call a local servicer and get a rough estimate of what it will cost you, first.
Then determine which way you want to go, new unit or repair.
Sorry for the bad news,
Good Luck,
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
SidexSide Fridge/Freezer not cold; tried to self-diagnose (Refrigerator & Freezer Repair)
by kenroehr 2/1/2018 6:10:10 AM(UTC)
Refrigerator & Freezer Not Cold - Evap Coils Frosted Over (Refrigerator & Freezer Repair)
by gciccol 12/13/2017 1:32:46 PM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Non-defrosting upright freezer not cold on bottom (Refrigerator & Freezer Repair)
by KOP264 6/12/2017 4:38:01 AM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
