My refridgerator is constantly running. The tempurature in the freezer and the fridge seem to be ok. I am not using a thermostat. I have heard this could be a problem with my defrost timer or the cold control switch. How can I test this to be sure.
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
It does sound like the defrost timer might be bad. When did you first notice that your fridge was always running? Keep in mind that your refrigerator has a 16 hour timer. This means that it stays on for 16 hours, then off for 35 minutes to defrost. Most timers are 6-8 hours, which makes it easier to notice when the fridge turns off (goes into defrost). Try measuring the temperature inside both the fridge and the freezer section with a refrigerator thermometer and post your results here. Breakdown diagrams for Model TPX21PRXDWW
We have noticed this problem for over a couple of weeks.
I took the tempurature of the freezer and fridge. They are 41 for the fridge and 1 degree for the freezer.
I already cleaned the coils on the bottom of the refridgerator. They were'nt that dirty.
