Hi, my dryer is not heating the way it should. I have to turn it on 2 or three times to dry. The timer turn as it should,the duct work is clean,its almost like its stuck on a lower temp. setting. Help please what can it be? Thanks!
It could very well be plugged up with lint build up inside the dryer. On this model dryer I often find lint build up around the heating element and blower housing.
