Lloyd Kneller
#1 Posted : Tuesday, September 25, 2007 1:03:54 PM(UTC)
Lloyd Kneller
The washer fills up and stays on the same cycle until it is moved to the next by hand. I am trying to replace the timer and I am having trouble separating the dial from the time. How do I go about separating the dial from the timer?
#2 Posted : Wednesday, September 26, 2007 1:18:57 AM(UTC)
The knob just unscrews after pushing it in. If not, you have a stripped plastic part that couples the shaft to the big plastic cam. Will need to pull timer cover and jam plastic cam to remove.
I used to have a bucket of used timers to repair this.If you have a plastic timer, just pull out the plastic tab in the back of timer, then knob pulls out.
Auto-dry setting timer does not advance (Dryer Repair)
by herseywa 6/16/2020 11:35:45 AM(UTC)
Timer does not advance (Washer Repair)
by Ray F 8/10/2015 6:13:40 PM(UTC)
Whirlpool (Roper) electric dryer runs and heats. Timer does not advance in auto or ti (Dryer Repair)
by biomed172 10/10/2014 6:12:03 PM(UTC)
No Heat, Timer Does Not Advance (Dryer Repair)
by MRGETITFIXED 8/27/2014 8:36:01 AM(UTC)
washer tub full spins but water still in timer does not advance (Washer Repair)
by scooty1 3/10/2013 6:55:34 AM(UTC)
Amana Dryer Timer Does Not Advance in Auto Mode (Dryer Repair)
by splehigh 3/5/2013 6:15:29 PM(UTC)
Whirlpool Dryer - No heat, Timer Does Not Advance (Dryer Repair)
by katielove22 10/21/2012 12:26:02 PM(UTC)
NO Heat - Timer does not advance (Dryer Repair)
by JMWITT 3/18/2012 6:08:06 PM(UTC)
Electric Dryer Not Producing Heat & Timer Does Not Advance in Auto Dry Settings (Dryer Repair)
by hifroggyjenn 1/12/2012 10:26:47 AM(UTC)
Maytag gas dryer. Timer does not advance and does not heat. (Dryer Repair)
by lfregia 11/27/2010 9:18:06 AM(UTC)
maytag dryer timer does not advance (Dryer Repair)
by Carbon 7/23/2010 3:33:04 PM(UTC)
Timer does not advance dryer runs no heat (Dryer Repair)
by Rmelc1 7/20/2009 1:25:42 PM(UTC)
Timer does not advance in auto mode (Dryer Repair)
by rman 6/27/2009 11:10:43 AM(UTC)
Timer does not advance in auto dry mode (Dryer Repair)
by Teager 6/16/2009 1:56:42 PM(UTC)
Amana Dryer dries slowly, and More/Less Dry Timer does not advance (Dryer Repair)
by dtshenoy 4/13/2009 6:24:55 AM(UTC)
