My washer goes through the whole cycle; however, at the end of the cycle, I noticed the machine is not draining. I can hear a noise during the spinning process but I'm not sure its actually spinning to its full capacity.
Washer is not draining or spinning. cw7000w-Crosley
Originally Posted by: br2pxg  My washer goes through the whole cycle; however, at the end of the cycle, I noticed the machine is not draining. I can hear a noise during the spinning process but I'm not sure its actually spinning to its full capacity. Machine not spining crosley cw7000w
Ok, did it or did it not drain?
