holzie69
#1 Posted : Tuesday, August 19, 2008 6:29:09 AM(UTC)
holzie69
my dishwasher will fill up with hot water, then instead of moving to
a wash cycle, it drains the water back out. then it just hummms.
it's not going thru the wash or rince cycles. It does not matter which cycle i start with i tried pot&pans , just rinse , or normal wash. none of
these cycles work. it just fills then empties....can you help??
thank you......
brian
libertyappl
#2 Posted : Tuesday, August 19, 2008 6:34:17 AM(UTC)
libertyappl
can you post the model number for your machine, it's located around the dishwasher frame
Thanks,
Nat
holzie69
#3 Posted : Tuesday, August 19, 2008 6:38:07 AM(UTC)
holzie69
i can get you the model # tommoro i am at work
thanks
holzie69
#4 Posted : Tuesday, August 19, 2008 6:42:57 AM(UTC)
holzie69
i called my wife, the model # is gsd 4010 z00aa
thanks
brian
abadfish66
#5 Posted : Tuesday, August 19, 2008 6:47:59 AM(UTC)
abadfish66
Take the bottom access panel off, and to the left of the motor is your drain solenoid. This may be stuck in the down position, either by a water leak rusting it closed, or overheating which will cause the solenoid to melt. Check this solenoid first for movement and post back.
holzie69
#6 Posted : Tuesday, August 19, 2008 7:00:31 AM(UTC)
holzie69
Ok I Read That In One Of The Other Posts.
Thank You
Brian
holzie69
#7 Posted : Wednesday, August 20, 2008 4:42:05 AM(UTC)
holzie69
That Was It!!! I Went Home And Checked It, It Was Stuck In The Down Position. I Put Some Wd-40 On It And Worked By Hand Until It Moved Freely Again. Thier Is Some Rust On The Bottom Of The
Solenoid So I Probly Will Need A New One Soon. It Looks Like It Is Part Of A Assembly.
Thank You All
this Site Rocks!!!!! brian
