AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
dishwasher fills then drains without going thru wash cycle
my dishwasher will fill up with hot water, then instead of moving to a wash cycle, it drains the water back out. then it just hummms. it's not going thru the wash or rince cycles. It does not matter which cycle i start with i tried pot&pans , just rinse , or normal wash. none of these cycles work. it just fills then empties....can you help??
thank you...... brian
can you post the model number for your machine, it's located around the dishwasher frame Thanks, Nat
i can get you the model # tommoro i am at work thanks
i called my wife, the model # is gsd 4010 z00aa
thanks brian
Take the bottom access panel off, and to the left of the motor is your drain solenoid. This may be stuck in the down position, either by a water leak rusting it closed, or overheating which will cause the solenoid to melt. Check this solenoid first for movement and post back.
Ok I Read That In One Of The Other Posts.
Thank You Brian
That Was It!!! I Went Home And Checked It, It Was Stuck In The Down Position. I Put Some Wd-40 On It And Worked By Hand Until It Moved Freely Again. Thier Is Some Rust On The Bottom Of The Solenoid So I Probly Will Need A New One Soon. It Looks Like It Is Part Of A Assembly.
Thank You All this Site Rocks!!!!! brian
Dishwasher Repair
