ruselmyr
#1 Posted : Monday, August 18, 2008 4:03:19 AM(UTC)
ruselmyr
Hello,
I'm unsure how old it is,
Is there an easy way to place the door & switch assy. I've done it before, the switch is not problem it's the wire from the right rear to the left rear. Do I remove the white plastic top of the drum assy? Or just tough it out?
Thanks for any and all help
#2 Posted : Monday, August 18, 2008 6:59:27 PM(UTC)
Are you talking about the washer or the dryer?
Here are the break down diagrams for the Maytag laundry center Model LSE7806ACE
ruselmyr
#3 Posted : Tuesday, August 19, 2008 6:41:30 AM(UTC)
ruselmyr
It's the washer.
Door switch mounted in right rear corner with the wire running along the back to the left rear side.
Don
#4 Posted : Tuesday, August 19, 2008 12:47:00 PM(UTC)
Don,
I'm afraid I did not understand your question. What is wrong with your washer? Can you refer to diagrams part##?
ruselmyr
#5 Posted : Tuesday, August 19, 2008 1:20:55 PM(UTC)
ruselmyr
Good afternoon,
I need to replace the door switch part #AP204694 (12001514) Switch assembly with fuse. It is mounted on the right rear, the wire slips into a conduit or track to keep it out of the way of the washer drum and runs to the left rear where it plugs into the wiring harness. I'm not sure how a tech would do it. How hard it is to take the top cover off.
#6 Posted : Tuesday, August 19, 2008 2:19:21 PM(UTC)
Remove the washer front panel. Pull the washer off of the stand. Now you can remove the top panel and access the switch assembly and the wire harness.
ruselmyr
#7 Posted : Thursday, August 21, 2008 4:45:57 AM(UTC)
ruselmyr
Thank you Gene,
Part is arriving via UPS today, I'll install it tonight.
