tomtieppo
#1 Posted : 14 years ago
tomtieppo
The oven portion is not at the desired temperature setting. I set the oven temp. at 375 to cook a turkey. I returned home a couple hours later and the bird was barely cooked. Stove top and broiler seem to be working fine.
kayakcrzy
#2 Posted : 14 years ago
kayakcrzy
So, when you turn the oven on to Bake, does the bake element glow red. If not, you most likely have a burn't wire at the element, or the element is bad. Tom ApplianceEducator.com
tomtieppo
#3 Posted : 14 years ago
tomtieppo
Element glows but the burner does not light. Small amount of gas smell but after 3 - 4 minutes still will not light.
kayakcrzy
#4 Posted : 14 years ago
kayakcrzy
Ok, the part you need to replace is the ignitor. That is the part that glows. The part # is 12400035. The reason is, that the ignitor is not strong enough to open the gas valve. So replace it, and you will have it. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Magic Chef RV Parts (Appliance Parts)
by Jerry Funk 3 years ago
Magic chef single wall unit (Oven Repair (including Ranges and Cooktops))
by Guest 3 years ago
Magic Chef thermal fuse equivalent (Microwave Repair)
by bassclef78 3 years ago
Magic Chef refrigerator lost its coldness (Refrigerator & Freezer Repair)
by Guest 4 years ago
PTC Start Relay for Magic Chef wine/beer refrigerator (Refrigerator & Freezer Repair)
by dereknfoster 5 years ago
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 5 years ago
magic chef can cool but wont (Refrigerator & Freezer Repair)
by jsuss01 6 years ago
Magic Chef B 38HN 42TVW F4 then F2 error (Oven Repair (including Ranges and Cooktops))
by steviemcstevesteve 6 years ago
Magic Chef Refrigerator and Freezer Warm Intermittenly (Refrigerator & Freezer Repair)
by delmar858 6 years ago
Magic Chef Mini Fridge - I can't find parts or part numbers (Refrigerator & Freezer Repair)
by domwebhost 8 years ago
16 year-old Magic Chef started making loud popping sounds (Refrigerator & Freezer Repair)
by webgrunt 8 years ago
Magic Chef freezer not freezing. (Refrigerator & Freezer Repair)
by DavidESny 9 years ago
Magic Chef Circuit Reset? (Oven Repair (including Ranges and Cooktops))
by TheBlackSwapper 9 years ago
Magic Chef Heavy Duty Washer (Washer Repair)
by SandyMesman 10 years ago
Magic Chef oven/broiler ignition problem (Oven Repair (including Ranges and Cooktops))
by steve_page@ymail.com 10 years ago
