mennoman
#1 Posted : Tuesday, November 23, 2010 3:55:11 PM(UTC)
mennoman
I have a dw that will run for about 7-9 minutes then shut down with the heat dry and high temp leds flashing. Troubles shooting guide indicates that that the dw has entered into a power failure mode. I have replaced the control board and have the same fault. Door latch and all wiring connections are good.Any suggestions.
#2 Posted : Tuesday, November 23, 2010 6:35:50 PM(UTC)
Very likely the problem is a bad selector switch (#8 on the diagram)
- The selector switch Part number: AP3267261
Whirlpool Side By Side Ice Maker Power Failure (Refrigerator & Freezer Repair)
by Bollweevil 9/29/2023 6:11:03 PM(UTC)
Maytag refrigerator not rebooting after power failure !!! (Refrigerator & Freezer Repair)
by MoreCowbell 11/29/2019 1:56:41 PM(UTC)
Dryer power failure (Dryer Repair)
by ClotheslineChris 11/23/2017 2:35:14 PM(UTC)
display dead after power failure (Oven Repair (including Ranges and Cooktops))
by kckoberg 6/29/2015 7:28:17 PM(UTC)
Maytag Bravos Electric dryer not working after Power failure (Dryer Repair)
by JohannesB 6/29/2015 3:16:19 AM(UTC)
Whirlpool blinking "Normal" light after power failure (Dishwasher Repair)
by Solow 12/29/2014 11:31:32 AM(UTC)
Power failure alarm keeps coming on. (Refrigerator & Freezer Repair)
by billco 10/1/2014 2:18:37 PM(UTC)
After power failure, no power to compressor (Refrigerator & Freezer Repair)
by tractorman44 11/25/2013 4:03:19 AM(UTC)
Power Failure goes off several times (Refrigerator & Freezer Repair)
by jlaval 8/31/2013 5:02:52 AM(UTC)
Power failure now no time display (Microwave Repair)
by hollywood1962 5/17/2013 7:04:12 PM(UTC)
Amana Oven Fails after Power Failure (Oven Repair (including Ranges and Cooktops))
by newatappliancerepair 2/4/2013 9:05:57 PM(UTC)
PF code (Power Failure) on clock will not reset (Oven Repair (including Ranges and Cooktops))
by lmevans 12/9/2012 2:26:02 PM(UTC)
freezer wont defrost, after power failure (Refrigerator & Freezer Repair)
by icebeast 8/13/2012 9:15:25 PM(UTC)
power failure code (Oven Repair (including Ranges and Cooktops))
by fixitman20111 12/1/2011 7:40:52 PM(UTC)
Litton Microwave No Power Failure (Microwave Repair)
by Bob B 8/17/2009 4:23:21 PM(UTC)
