This unit works sporadically. It seems that as soon as I tap the control panel (cold control area) the unit stars up and works great for a while. It seems to stick in the off cycle until I tap the panel again.
Someone said the thermostat was bad or maybe the timer. Any help please
Originally Posted by: bobkgl This unit works sporadically. It seems that as soon as I tap the control panel (cold control area) the unit stars up and works great for a while. It seems to stick in the off cycle until I tap the panel again.
Someone said the thermostat was bad or maybe the timer. Any help please Bob, It could be a loose connection as well. Disconnect the wires from the temperature control and defrost timer, Check the wire ends ( terminal )for discoloration and a proper tight crimp. If the wires are OK, start with the cold control replacement. Part number: AP3037004
Have a good day, :cool: :cool: :cool:
Thanks Joe. I will check it today and let you know.
Originally Posted by: bobkgl Thanks Joe. I will check it today and let you know. Bob, Good deal, Look forward to your update, :cool: :cool: :cool:
finally got a chnace to work on this unit. Bought the timer and cold control and installed both. Seems to be working fine now. I guess it was not the connections.
Thanks so much for all your help and provinding a quick place to gt the parts needed
Originally Posted by: bobkgl finally got a chnace to work on this unit. Bought the timer and cold control and installed both. Seems to be working fine now. I guess it was not the connections.
Thanks so much for all your help and provinding a quick place to gt the parts needed Bob, Good Job. You're quite welcome. We're happy to have been able to help. :D :D :D
