bobkgl
#1 Posted : Friday, November 5, 2010 10:20:07 AM(UTC)
bobkgl
This unit works sporadically. It seems that as soon as I tap the control panel (cold control area) the unit stars up and works great for a while. It seems to stick in the off cycle until I tap the panel again.
Someone said the thermostat was bad or maybe the timer. Any help please
Joe / APP Team
#2 Posted : Friday, November 5, 2010 1:46:59 PM(UTC)
Joe / APP Team
Bob,
It could be a loose connection as well.
Disconnect the wires from the temperature control and defrost timer,
Check the wire ends ( terminal )for discoloration and a proper tight crimp.
If the wires are OK, start with the cold control replacement.
Part number: AP3037004
Have a good day,
:cool: :cool: :cool:
bobkgl
#3 Posted : Saturday, November 6, 2010 5:56:23 AM(UTC)
bobkgl
Thanks Joe. I will check it today and let you know.
Joe / APP Team
#4 Posted : Monday, November 8, 2010 7:52:37 AM(UTC)
Joe / APP Team
Bob,
Good deal,
Look forward to your update,
bobkgl
#5 Posted : Friday, November 19, 2010 7:40:21 AM(UTC)
bobkgl
finally got a chnace to work on this unit. Bought the timer and cold control and installed both. Seems to be working fine now. I guess it was not the connections.
Thanks so much for all your help and provinding a quick place to gt the parts needed
Joe / APP Team
#6 Posted : Friday, November 19, 2010 8:55:00 AM(UTC)
Joe / APP Team
Bob,
Good Job.
You're quite welcome.
We're happy to have been able to help.
:D :D :D
