2 Pages12>
RWjr
#1 Posted : Friday, August 15, 2008 7:09:33 AM(UTC)
RWjr
My unit is not working properly, the fridge & freezer are not staying cold, I have cleaned the condenser coils, but the fan does not turn on, the light inside does, but no fan. Is their a reset button or switch or some test that will spare me the expense of calling the repairman.
abadfish66
#2 Posted : Friday, August 15, 2008 7:14:16 AM(UTC)
abadfish66
Is the compressor running, the condensor fan? Is the refer turned off?
RWjr
#3 Posted : Friday, August 15, 2008 7:17:24 AM(UTC)
RWjr
no to the first two, could not understand the last question.
abadfish66
#4 Posted : Friday, August 15, 2008 7:20:37 AM(UTC)
abadfish66
Just make sure the temp contol is turned on and not in the off position.
abadfish66
#5 Posted : Friday, August 15, 2008 7:21:17 AM(UTC)
abadfish66
Also can you get me the model#
RWjr
#6 Posted : Friday, August 15, 2008 7:25:42 AM(UTC)
RWjr
Control knobs are set to the right places ( on the arrows) the model # is FRT18P6BSB2
RWjr
#7 Posted : Friday, August 15, 2008 7:48:00 AM(UTC)
RWjr
abadfish66 are you still there?
abadfish66
#8 Posted : Friday, August 15, 2008 7:49:17 AM(UTC)
abadfish66
You need to locate this part----> AP2111929 as I cannot find a breakdown to tell you were it is. When you locate it, get a screwdriver and turn the dial and see if it comes on. Your refer may be stuck in defrost mode.
abadfish66
#9 Posted : Friday, August 15, 2008 8:19:37 AM(UTC)
abadfish66
Found the timer, in the freshfood section, up where the light is and stuff, the timer is located inside that plastic housing. Look on the underside of that housing, and you will see a hole about the size of a dime with a plactic piece in there, that is the timer dial. Put your screwdriver in there and turn it.
RWjr
#10 Posted : Friday, August 15, 2008 8:30:13 AM(UTC)
RWjr
what is the name of the part
2 Pages12>
