Ghite
#1 Posted : Saturday, September 22, 2007 2:35:58 PM(UTC)
Ghite
My Crosley washer will not spin in the spin cycle it starts to spin but then stops and just agitates. The lid switch is working because the motor starts in the spin cycle and runs and the tub tries to turn slowly sometimes. It appears to be mechanical problem. Any ideas?
#2 Posted : Saturday, September 22, 2007 3:45:34 PM(UTC)
You probably have a bad thrust bearing washer. Will need to install a thrust bearing kit with pulley. Pull front panel off and turn tranny pulley in spin direction, opposite from agitate. If no spin, this confirms bad thrust bearing washer. Go to Appliance repairs, Appliancehelp, Appliances, repairs to dryers washers dishwashers fridges repairs microwaves ge maytag kenmore frigidaire westinghouse inglis, appliance how to take apart information, purchasing an appliance help, model number help, for directions, this is basically a Maytag washer so follow directions for a Maytag.
Ghite
#3 Posted : Saturday, September 22, 2007 8:13:09 PM(UTC)
Ghite
Thanks It sounds like that is the problem. I appreciate the information.
#4 Posted : Sunday, September 23, 2007 1:22:05 AM(UTC)
The thrust assembly, when turned, pushes up a cam on the tranny pulley that releases the brake. If washers wear, the brake does'nt get released.
#5 Posted : Sunday, September 23, 2007 1:22:55 AM(UTC)
The thrust assembly, when turned, pushes up a cam on the tranny spindle that releases the brake. If washers wear, the brake does'nt get released.
dinki123
#6 Posted : Saturday, August 16, 2008 7:35:21 AM(UTC)
dinki123
i replace with new kit ; how do you adjust. instruction not clear. is there a speacial tool to put clip back on easier. the shaft does not seem to stick out for enoug
#7 Posted : Sunday, August 17, 2008 3:16:32 AM(UTC)
Wrap a towel around a piece of wood and stick it on top of the agitator, then force down the agitator by closing the lid and putting a toolbox on top.
This should help: Also, pry the shaft down with a flat bladed screwdriver to allow insertion of the C clip.
dinki123
#8 Posted : Sunday, August 17, 2008 6:22:14 AM(UTC)
dinki123
when reinstall the thrust bearing : the is a plactic peice that goes on after the metal bearing. the pic show the ears pointing toward the agitatotor. is this corect. i put mine with the ears pointing toward the pulley. i was not the one who originally took apart so im not sure which way it came out thanks.
#9 Posted : Sunday, August 17, 2008 8:22:49 AM(UTC)
The breakdown picture is usually right.
dinki123
#10 Posted : Sunday, August 17, 2008 9:15:39 AM(UTC)
dinki123
Ok Ill Try That Thank You Sooo Much
