notlek1b
#1 Posted : Tuesday, August 12, 2008 12:21:31 PM(UTC)
notlek1b
Refrigerator (side by side type) too warm. Both sides too warm. Things melted in freezer. Manual suggests cleaning off condenser coil, which I did. Compressor is working and is pretty warm on top "dome," suggesting to me that it has refrigerant and is compressing it. Condenser fan is working. I guess the evaporator fan is working, as some cool air coming in at the top of freezer. Temperature in freezer seems stuck at 42 F. Apparent return to compressor seems too warm.
Do you think there is some refrigerant, but not enough?
#2 Posted : Tuesday, August 12, 2008 7:27:12 PM(UTC)
Remove the rear panel in the freezer and check the evaporator coil. Normally it should be 100% covered with light snow. Post the result.
Frige not cold enough freezer fine+fix? (Refrigerator & Freezer Repair)
by tomsap 5/8/2022 2:02:41 PM(UTC)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
refridgerator section is not cold enough (Refrigerator & Freezer Repair)
by androidx1 6/8/2020 9:38:34 AM(UTC)
LG refrigerator lxfs28566s not cold enough. (Refrigerator & Freezer Repair)
by amagie00 5/16/2020 9:08:51 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
GE Bottom Freezer Ice Maker Not Cold Enough to Make Ice (Refrigerator & Freezer Repair)
by Fix4All 7/30/2019 10:45:51 AM(UTC)
freezer cold,fridge not cold enough (Refrigerator & Freezer Repair)
by BSTrue 11/18/2018 2:40:04 AM(UTC)
Fridge Not cold enough (Refrigerator & Freezer Repair)
by water101 1/10/2018 8:28:55 PM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
GE Refrigerator freezer and food not cold enough (Refrigerator & Freezer Repair)
by Jerrysing 9/30/2016 6:31:22 AM(UTC)
