JBear
#1 Posted : Sunday, August 26, 2007 12:14:33 PM(UTC)
JBear
[FONT="Arial"]:confused: [/FONT]
I need to replace some shelf support studs in the refer side of this unit and I have found the replacements but have no idea how to remove the old and broken ones. Can anyone out there help me out with this? I'm sure it is simple but I don't want to break the liner in my attempt to repair a shelf! :confused:
#2 Posted : Monday, August 27, 2007 10:33:18 AM(UTC)
Hi JBear
There are a few different studs used on this fridge. If you can post the part number fort the stud you're interested I might be able to help you.
mike t
#3 Posted : Friday, September 21, 2007 3:07:21 PM(UTC)
mike t
Part Number: AP59938
made by MAYTAG
i need instructions on how to replace the shelf stud listed above
mike t
#4 Posted : Friday, September 21, 2007 3:13:00 PM(UTC)
mike t
made by MAYTAG
JBear
#5 Posted : Friday, September 21, 2007 3:18:00 PM(UTC)
JBear
made by MAYTAG
Mike, I'm not sure if the Maytag part that you mention is the same as the Roper/Whirlpool part that I replaced, but I found that there are flat spots on the sides if these studs and that if you grasp those studs with a pair if pliers at the flat spots and turn them 90 degrees to the right they will then pull out quite easily. The replacement studs can then be inserted in the hole (I put in a small amount of silicone first to fill any voids) and then turned 90 degrees to the right again to lock them in place.
I hope this helps.
Burnymac
#6 Posted : Sunday, November 29, 2009 9:28:51 AM(UTC)
Burnymac
Sir, I have a whirlpool model number ED25TQXEW00, serial number SG2530847. I need to replace the shelf stud part # AP3109339 and shelf support kit part # AP3109341. Any advice on how to safely remove the old and install the new? Thanks.
