bob38
#1 Posted : Wednesday, September 19, 2007 11:15:49 AM(UTC)
bob38
the other day my wife was drying clothes and she stopped the dryer to add more clothes. when she tried to start it the dryer would not start.The front panel lights come on but the dryer will not start. The back panel was hot and I suspected the dryer vent was clogged so I pulled the dryer out and the vent was clogged with lint and water. The vent pipe has to run approximately 17 feet with four turns before the hot air vents to an open area and I know this is a major problem. After clearing the vent lines I took of the front kick panel to inspect the thermal fuse which was still getting an Ohm reading so it should be good.....right? I then took off the back panel and noticed that lint was all over the the inside of the dryer. Must have been clogged for a while. After cleaning the interior of the dryer I checked the door switch. It tested fine. Now I'm looking at the control panel to see if the high heat could have damaged the control board or anything else. Am I on the right track? what do you suggest?
Matt / APP Team
#2 Posted : Wednesday, September 19, 2007 5:29:57 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
I would start with checking the thermal fuse and thermal limiter.
Thermal fuse
Click for thermal limiter.
If its bad replace it. Did you test it with the wires off?
And do something to shorten up that vent or have it cleaned more often!
Check it out and let us know!
bob38
#3 Posted : Wednesday, September 19, 2007 6:59:45 PM(UTC)
bob38
Have not tested the thermal limiter. Hovever, I did get the dryer to run and blow hot air. Then I turned the dryer off and tried to start it again. It would not start. Would this be the thermal limiter or something wrong with the control board?
Guest (4)
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
