Oven w'ont heat to temp. It will heat to aprox 250 degrees when set to 450. Broiler works fine. Is this a sensor problem or something else? Thank you, Jim
Originally Posted by: cuttem  Oven w'ont heat to temp. It will heat to aprox 250 degrees when set to 450. Broiler works fine. Is this a sensor problem or something else? Thank you, Jim Jim, Yes , it could be a bad sensor, Do you have a multimeter to test the sensor resistance ? Were it me , I would start at the bake element itself. I would check for, cracked or melted area(s) on the element coating. I would also remove the element mounts and check for loose or melted connections, or wires, you may even want to test for 240 volts on the element terminals, in a bake cycle, then test the sensor circuit and control if all checks OK. Good Luck, :cool: :cool: :cool:
