Steve Arthur
#1 Posted : Tuesday, November 9, 2010 11:32:38 AM(UTC)
Steve Arthur
Stainless Steel Kitchen Aid oven issue--opened oven door and let it fall freely (mistake)--door will now not close the last inch or so, it is just open enough for the light to stay on--nothing appears bent or broken--springs in door are fine--have removed door and reinstalled several times--repair center guy can find nothing wrong--any ideas
Joe / APP Team
#2 Posted : Tuesday, November 9, 2010 12:51:31 PM(UTC)
Joe / APP Team
Steve,
Sounds like you may have damaged the door hinges, recievers or supports.
Hopefully, you did not damage the oven cavity front panel.
Check the oven front panel for chipped porcelain or a bulge (out) in the area around the opennings for the door hinges, that would require a new front panel.
Also check the inner door liner for the same situation(chips and bulges).
Part number: AP3673245
Otherwise, you need to suspect a bent hinge, hinge reciever, reciever support.
Part number: AP3083224
Part number: AP3132737
Part number: AP3043872
Part number: AP3037816
It may sound and look daunting, but it's not that bad.
Good Luck,
oven door will not close (Oven Repair (including Ranges and Cooktops))
by gabe_1981 6/28/2012 3:56:52 PM(UTC)
Jenn Air oven door will not close (Oven Repair (including Ranges and Cooktops))
by embdenb 9/3/2009 10:48:19 AM(UTC)
