Oven w'ont heat to temp. It will heat to aprox 250 degrees when set to 450. Broiler works fine. Is this a sensor problem or something else? Thank you, Jim
Originally Posted by: cuttem  Oven w'ont heat to temp. It will heat to aprox 250 degrees when set to 450. Broiler works fine. Is this a sensor problem or something else? Thank you, Jim This is a duplicate post, dis regard
