Water leaks out the front of the refrigerator. The drain hose in the bottom of the refrig is not blocked.
Randy, Most likely the problem is a clogged and/or frozen drain hole under the evaporator inside the freezer. Here are the break down diagrams for the Amana refrigerator Model NT19G7Gene.
