SherryA
#1 Posted : Friday, October 29, 2010 6:58:30 AM(UTC)
SherryA
Hi all..
I have a Whirlpool Gold Senseon Dryer, Gas. It has not been used for a couple of months. It spins, but will not heat up. The gas line is fine and it is getting gas.
Any thoughts?
Thanks!
Sherry
Joe / APP Team
#2 Posted : Friday, October 29, 2010 10:56:24 AM(UTC)
Joe / APP Team
Originally Posted by: SherryA Go to Quoted Post
Hi all..
Any thoughts?
Thanks!
Sherry
Sherry,
Remove the small plastic cover on the front panel, and start the dryer in a dry cycle.
Observe the operation of the gas valve :
1) You should hear a click when you start the cycle.
2) You should see an orange glow from the igniter.
3) You should see the glow subside and see or hear the gas release and
burner flame ignite.
You could have any one of several failures,
Do this check, and let us know what you observe, and we can get a better idea of which direction to take.
SherryA
#3 Posted : Friday, October 29, 2010 1:22:54 PM(UTC)
SherryA
Hi Joe
Thank you for the response...My dryer does not have a small plastic front cover panel though??
Joe / APP Team
#4 Posted : Friday, October 29, 2010 3:41:46 PM(UTC)
Joe / APP Team
Hi Joe
Sherry,
I'm lost now,
You should have ?
Part number: AP3094215
But either way, you will need to listen for the ignition procedure,
Good Luck,
:cool: :cool: :cool:
SherryA
#5 Posted : Saturday, October 30, 2010 5:58:53 AM(UTC)
SherryA
Joe
The picture that you posted on my dryer is all metal, that is why I was confused. Do I need to remove that whole front cover to get to the ignition, because it is one big metal piece.
Thanks,
Sherry
Joe / APP Team
#6 Posted : Monday, November 1, 2010 10:42:33 AM(UTC)
Joe / APP Team
Joe
Thanks,
Sherry
Sherry,
If you're sure you do not have a 2x2 inch plastic square panel on the lower area of the front panel.
How about a complete lower access panel, approximately 9 inches high and the full width of the dryer ?
If you have neither, I'd be surprised, but yes you will need to remove the front panel, and several other components to access and observe the gas valve and burner assembly.
:confused: :confused: :confused:
SherryA
#7 Posted : Monday, November 1, 2010 2:41:04 PM(UTC)
SherryA
Joe..
I swear I dont have either of those! The front of my dryer is complete metal. It has that tiny little hole at the bottom left, but it is a completely one piece of metal. I took a picture to show you, but cant figure out how to post it here! :-)
Joe / APP Team
#8 Posted : Monday, November 1, 2010 4:06:36 PM(UTC)
Joe / APP Team
Joe..
Sherry,
That tiny little hole in the front panel bottom left, is what I'm looking for.
(apparently your plastic cover has fallen / broken off ?(the hole does look like the hole in the picture I sent you in a previous post).
That's the "peep hole" you need to use to observe the ignition procedure.
How to check / observe the ignition procedure :
Put the timer dial in a timed dry selection.
Make sure, Regular or high heat temperature selection is made.
Start the mahine.
In a split second you should hear a "click".
Look at or into (not too close) the "peep hole".
You should see a bright orange glow,
And after a few seconds, the glow will start to dim,
You should be able to hear the gas Ignite (swoosh noise) and see a blue flame through the "peep hole".
Observe for a couple of cycles(5 minutes) and let us know what occurs.
We'll have a better idea of what to expect, if you do.
Thanks,
