Oven turns on, begins to pre-heat, and continues to get hotter -- much above desired temp, displays F1 code, beeps, only way to stop is unplug.
Any ideas? Looking around, it seems to imply a bad system board...if this is the case, is it something I can order and replace, or do I need to call tech?
Thank you.
THIS FORUM IS DEAD!!!!!!! |
