wellik
#1 Posted : Friday, October 29, 2010 7:39:55 AM(UTC)
wellik
Oven turns on, begins to pre-heat, and continues to get hotter -- much above desired temp, displays F1 code, beeps, only way to stop is unplug.
Any ideas? Looking around, it seems to imply a bad system board...if this is the case, is it something I can order and replace, or do I need to call tech?
Thank you.
#2 Posted : Saturday, October 30, 2010 2:53:40 AM(UTC)
Here are the parts
Replacement parts for KENMORE 79095201103 | AppliancePartsPros.com
Part number: AP3672811
This may help if you decide to replace it yourself, thoughit does cover lots of different units.
http://frigidaireservicetips.com/pdfs/477_5.pdf
wellik
#3 Posted : Saturday, October 30, 2010 8:23:46 AM(UTC)
wellik
Thanks for your help...
