kreuter
#1 Posted : Friday, October 15, 2010 10:55:19 AM(UTC)
kreuter
I recently replaced our countertops and had to move our dishwasher around. Since then my dishwasher leaks water out the bottom of machine under the door. It only leaks during the rinse cycle. Is it not draining fast enough or what is the problem?
Joe / APP Team
#2 Posted : Friday, October 15, 2010 12:04:48 PM(UTC)
Joe / APP Team
Kreuter,
Check and make sure the drain hose is installed proper and has no bad twists or kinks.
The drain pump should have the water drained out in 20 to 30 seconds or less,
(let unit fill and wash foe 3-5 minutes, then drain unit and check time).
Check and make sure the dishwasher is level in both directions,
All 4 feet are on the floor, solid.
Insure that the door to tub alignment is proper.
Check and adjust door catch if necessary.
Check lower spray arm for proper rotation, and no stalling.
Run the unit through a short cycle (with out detergent) and see if leaks occur.
If it still leaks after that(in the rinse cycle only) suspect the rinse agent is foaming and blowing out the bottom of door.
Make sure you use the proper amount and type of detergent, per the user's manual.
Good Luck,
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
Samsung french door bottom freezer loud buzzing and water leak (Refrigerator & Freezer Repair)
by surgeslayer2 10/19/2023 3:33:56 AM(UTC)
Speed Queen washer water leak (Washer Repair)
by Guest 5/20/2023 4:29:11 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Whirlpool fridge water leak not solvable with ptrap (Refrigerator & Freezer Repair)
by richdell 5/2/2021 5:33:45 AM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 4/13/2019 9:06:58 AM(UTC)
