Saxy
#1 Posted : Thursday, October 14, 2010 10:14:30 AM(UTC)
Saxy
Using the oven yesterday, the oven stayed on 425 degress, where I had it set, and would not cool down after turning controls off. After a couple hours, we finally turned the breaker off in the main box. A very helpful friend came to dinner and suggested the temperature control needed replacing. After searching on the GE site, I'm still not 100% sure which switch is the right one to replace. None are labeled temperature control. The diagrams are not specific enough for me. I can do the replacing once I get the right piece. Any advice would be appreciated. Thanks.
Joe / APP Team
#2 Posted : Thursday, October 14, 2010 12:00:26 PM(UTC)
Joe / APP Team
Saxy,
You need the Electronic Range Control (ERC).
Part number: AP2632445
Have you checked or attempted to use the range since it happened ?
You might want to try it again, and you may want to remove the back panel and check the wiring for shorted, melted, areas, first.
Saxy
#3 Posted : Thursday, October 14, 2010 12:38:46 PM(UTC)
Saxy
Thanks Joe. I had the back removed and see the part you reference. The description says there may be wiring differences. Is that the norm or the exception? I know enough to be dangerous but not enough to fix my mistakes. I have plugged the oven back in and turned it on. I smell nothing unusual nor see anything that I can tell is out of the ordinary. After I turn it off, I will know if it cools back down, but unlike a computer, I doubt a reboot works with appliances.
Thank you again for the help.
Joe / APP Team
#4 Posted : Thursday, October 14, 2010 1:44:40 PM(UTC)
Joe / APP Team
Saxy,
I seldom had to re wire the control.
As far as I can remember, it was a matter of wether there was or was not a green ground wire terminal, and wether to attach it or not.
Actually, sometimes a "reboot" does work, I'm hoping that's the case now.
Saxy
#5 Posted : Thursday, October 14, 2010 2:32:15 PM(UTC)
Saxy
Thanks. Reboot didn't work. The part is ordered and should work out ok. Now at least I know where I'm headed with it.
Joe / APP Team
#6 Posted : Friday, October 15, 2010 5:04:16 AM(UTC)
Joe / APP Team
Great,
Let us know what you find
Good Luck,
:cool: :cool: :cool:
temperature control not working properly (Washer Repair)
by garywool93 3/9/2015 3:30:16 PM(UTC)
