RIC109
#1 Posted : Tuesday, October 12, 2010 7:26:41 AM(UTC)
RIC109
Yesterday, I just used the dryer to dry a load of clothes and it worked fine. On the second load, it would not turn on at all. I tried different cyles, but still no luck. I did get the drum to turn once on the wrinkle shield cycle but it has not done anything since then. I have not checked the continuity on any switches or fuses. I would like to know in which direction to start. Thanks!
magician59
#2 Posted : Tuesday, October 12, 2010 11:26:23 AM(UTC)
magician59
First place to check is the power source. You should see 240 VAC between the two hot lines; and 120VAC between each hot lline and the ground. If the outlet is good, check the connections at the back of the dryer.
RIC109
#3 Posted : Wednesday, October 13, 2010 6:12:34 AM(UTC)
RIC109
Thanks for the tip! I'll check that. I did check the thermal fuse and thermostats in the back of the dryer for continuity. Everything tested fine except for the cycling thermostat on the blower housing below the thermal fuse. The two outer posts had continuity, but the two inner posts had resistance. Does this mean that it is bad and if so will that keep the dryer from working at all? Thanks for the help!
magician59
#4 Posted : Wednesday, October 13, 2010 6:21:44 AM(UTC)
magician59
That is a normal reading. The two inner posts are contacts for the internal heater that helps regulate the thermostat in the various heat level selections for your timed dry cycles.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
