My first problem was that the drier would shut down and the timer appeared to advance to off very quickly and of coarse things werent dry but they would be warm.So i changed the timer and it still shuts down about everyother time now. But now when it quits i cant restart it unless i turn the timer to off and reset .And i also hear the heater cycling at times.The lint trap was clogged alot but i cleaned inside and out .Im puzzeled .But sense replacing the timer it better but its not correct.HELP Thanks
You probably need to take the dryer apart and clean it up real good. I bet is is full of lint,Check you lint trap and your vent  SublimeMasterJW attached the following image(s):
