partsman
#1 Posted : Sunday, July 27, 2008 6:19:03 PM(UTC)
partsman
My first problem was that the drier would shut down and the timer appeared to advance to off very quickly and of coarse things werent dry but they would be warm.So i changed the timer and it still shuts down about everyother time now. But now when it quits i cant restart it unless i turn the timer to off and reset .And i also hear the heater cycling at times.The lint trap was clogged alot but i cleaned inside and out .Im puzzeled .But sense replacing the timer it better but its not correct.HELP Thanks
SublimeMasterJW
#2 Posted : Monday, July 28, 2008 8:45:46 AM(UTC)
SublimeMasterJW
You probably need to take the dryer apart and clean it up real good. I bet is is full of lint,Check you lint trap and your ventGVI 151.jpg
SublimeMasterJW attached the following image(s):
dryer shuts down on high heat (Dryer Repair)
by wwager 10/2/2017 12:04:47 PM(UTC)
Dryer shuts down (Dryer Repair)
by Shay Hughes 2/12/2013 10:36:01 AM(UTC)
by Shay Hughes 2/12/2013 6:55:12 AM(UTC)
Frigidaire dryer shuts down (Dryer Repair)
by richappy 5/15/2012 2:12:38 PM(UTC)
Maytag Electric Dryer Shuts Down (Dryer Repair)
by walkthesky 10/7/2010 9:17:37 AM(UTC)
Electrolux dryer shuts down immediately (Dryer Repair)
by firest02 9/10/2010 5:11:22 PM(UTC)
by 88dave 12/5/2009 1:51:25 PM(UTC)
HP fault code. dryer shuts down (Dryer Repair)
by panman 1/4/2009 4:56:22 PM(UTC)
heat dryer shuts down (Dryer Repair)
by basketballcoach322 12/24/2008 10:19:57 AM(UTC)
Dryer shuts down just before cooldown (Dryer Repair)
by mrmeld 1/20/2008 11:12:07 AM(UTC)
