junebuggy1
#1 Posted : 18 years ago
junebuggy1
My Roper washer isn't agitating correctly. If I push down on it while running it will work a little and it can be turned by hand when not on. It makes a sort of grinding sound when running and doesn't turn much
Matt / APP Team
#2 Posted : 18 years ago
Matt / APP Team
Rank: Administration
Groups: Administrators
Click for parts breakdown: Click here
Is it just the upper portion of the agitator that is not working? If so you may need the agitator repair kit.
Click here: Agitator repair kit
If the whole agitator doesnt move and the grinding is down at the bottom it could be you transmission going out. First check out the upper agitator and see if thats the problem and let us know!
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 9 months ago
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 9 months ago
GE Top load washer not draining (Washer Repair)
Washer won’t spin with load (Washer Repair)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 10 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 10 months ago
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 10 months ago
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 10 months ago
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 10 months ago
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 10 months ago
Whirlpool duet washer front load (Washer Repair)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 10 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 11 months ago
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 11 months ago
GE washer grinding noise (Washer Repair)
by gefixin 11 months ago
