thronedoggie
#1 Posted : Sunday, October 3, 2010 7:15:22 PM(UTC)
thronedoggie
We have a GE jvm1540dm1bb model microwave that is installed in our condo (I am not sure of the age, but I put 1-5 years because it looks new)
On Friday the touchpad stopped responding. I unplugged the unit to reboot it, and then the display above the touchpad went into a sort of frozen mode with asterisks in the date/time area and
timer NITE help REM MUTE AMPM (battery pic)
below that.
No button will respond, nor beep. Deader'n a doornail.
What should I do?
thanks,
jim p.
magician59
#2 Posted : Sunday, October 3, 2010 7:22:51 PM(UTC)
magician59
You might want to first check the integrity of the power source, as well as for proper polarity. If all's well at the outlet, I would look into replacing the smart board.
Part number: AP3994110
thronedoggie
#3 Posted : Wednesday, October 6, 2010 7:33:46 AM(UTC)
thronedoggie
Well, I ordered the smart board, assuming that it would come with some installation instructions - but it's just a smart board, in bubble wrap.
Googling hasn't helped me either - all I found when I googled was my own post from the other day :)
Any pointers or links?
thanks,
jim p.
magician59
#4 Posted : Wednesday, October 6, 2010 10:01:03 AM(UTC)
magician59
Before you take out any parts or disconnect any wires from the old board, make sure your new board matches up with the old one. A good idea is to take a digital photo of the original, so that if yu forget what goes where, you'll have a visual record.
If you can, transfer wire connectors one at a time, from the old to the new.
