Pauly H
#1 Posted : Friday, October 1, 2010 12:35:59 PM(UTC)
Pauly H
I have a Maytag front loading dryer. The control panel will not respond to any requests, no lights, no responses. I was told that this could be a pc board. What would cause the control panel to stop working and how can I fix it?
#2 Posted : Friday, October 1, 2010 2:19:51 PM(UTC)
Replacement parts for MED9600SQ models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208563816.pdf
If the unit seems totally dead.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Note: If the interior light works then L1 to Neutral is OK and this is the half of the line that runs the control board.
Then the first thing to check would be the door switch.
Pauly H
#3 Posted : Thursday, October 21, 2010 8:43:02 AM(UTC)
Pauly H
I have checked the L1 and L2, both are good. The manufacturer suggested that I replace the control panel board. How do I take off the front of the dryer to check the door switch and the connections to the front panel?
Control panel has no error but status shows sensing mode light ON (Dryer Repair)
by Neil74 4/28/2024 6:56:25 AM(UTC)
Subzero 650 Control Panel (Refrigerator & Freezer Repair)
by kbf99 2/14/2024 5:06:04 AM(UTC)
Control panel goes dark and loud clicking noise (Refrigerator & Freezer Repair)
by Guest 2/6/2024 12:57:10 PM(UTC)
Control panel for GE Spectra Stove Model # JBP79WB4WW (Appliance Parts)
by janieben@rainbowtel.net 1/22/2024 5:16:12 PM(UTC)
LG LFXS28968S /00 control panel removal (Refrigerator & Freezer Repair)
by Guest 11/15/2023 5:36:56 PM(UTC)
Whirlpool Control Panel VOM Testing (Washer Repair)
by Guest 10/19/2023 10:23:21 AM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
LG control panel issue (Dishwasher Repair)
by Guest 9/10/2023 7:18:58 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Dispenser control panel is dead (Refrigerator & Freezer Repair)
by Expat 1/21/2023 1:56:42 PM(UTC)
Kitchenaid Control panel melted (Dishwasher Repair)
by Guest 12/9/2022 2:41:47 PM(UTC)
Whirlpool WRF555SDHV refrigerator dispenser control panel (Refrigerator & Freezer Repair)
by janinePR 12/8/2022 2:17:23 PM(UTC)
GE GSS25WGTGBB - Control panel dies when turning on dispenser light (Refrigerator & Freezer Repair)
by noparts 9/19/2022 6:17:40 AM(UTC)
Maytag MHWE300VW00 Control Panel shuts off, then on, then off... (Washer Repair)
by ab2112 8/1/2022 10:00:14 AM(UTC)
