Bill Meyer
#1 Posted : Wednesday, September 29, 2010 9:46:03 AM(UTC)
Bill Meyer
Ice maker just quit, I have replaced water valves and still not working. The green light goes on when you first turn on maker then it starts flashing, What could be the problem.
Thanks, Bill
Bill Meyer
#2 Posted : Wednesday, September 29, 2010 11:49:43 AM(UTC)
Bill Meyer
Thanks, Bill
I have also changed water filter and ran water till it comes out the door.
Joe / APP Team
#3 Posted : Wednesday, September 29, 2010 12:15:08 PM(UTC)
Joe / APP Team
Thanks, Bill
Bill,
The flashing green light indicates a failure in the control, thermistor or the ice maker is in a harvest mode.
The on-off rocker switch allows the
icemaker to be turned off. When the switch
is set to on, a green LED on the right side of
the cover will light to show power is on. The
LED is also used to indicate certain icemaker
fault conditions, such as an open or shorted
thermistor, or a harvest cycle longer than 30
minutes. When a fault occurs, the LED will
blink 1/2 second on, 1/2 second off indefinitely
until the icemaker is turned off
If It's not in a harvest mode, you'll need a new ice maker assembly.
Part number: AP4345120
Here is a copy of the service test instructions for your ice maker.
Service Diagnostics
During the first 15 seconds that power
is first applied to the icemaker, the Service
Diagnostic Test mode may be entered. The
service mode is entered by pushing the feeler
arm from the
outposition to the inposition
and back again 3 times and only 3 times within
15 seconds.
Note
: If the icemaker has already started a
harvest cycle and the arm is moving, it may be
impossible to properly move the arm and enter
the service mode without allowing it to reset
and powering up again.
The service diagnostic mode consists
of a harvest cycle followed by a water
fill.
The harvest cycle is entered immediately, regardless
of icemaker temperature or arm position.
While in the harvest cycle in the service mode,
the heater will remain on for a minimum of 20
seconds. The water fill cycle will initiate the
first fill (5.1 seconds) without waiting for the mold
to
prechill. Only one water fill occurs during
the service mode, whether the thermistor has
reached 39.2
°F (4°C) or not. The icemaker will
exit the service diagnostic test on its own and
enter the normal freeze cycle.
NOTE
: When replacing an icemaker, the Power
On test will probably occur since the mold
temperature will be above 50
°F (10°C). While
in the power on test, the Service Diagnostic test
can be initiated and will override the power on
test mode.
Good Luck,
Bill Meyer
#4 Posted : Wednesday, September 29, 2010 12:28:12 PM(UTC)
Bill Meyer
Originally Posted by: Joe / APP Team Go to Quoted Post
Bill,
Service Diagnostics
arm from the
15 seconds.
Note
fill.
to
reached 39.2
NOTE
°F (10°C). While
test mode.
Good Luck,
Is the feeler arm what kicks out the ice?
Joe / APP Team
#5 Posted : Wednesday, September 29, 2010 1:43:11 PM(UTC)
Joe / APP Team
Bill,
The feeler arm is the white "paddle" on the bottom of the ice maker assembly.
As the ice accumulates in the bucket, the cubes push against the paddle,the paddle eventually moves "in" and shuts off the ice maker until it moves "out" and restarts the icemaking procedure.
The arm that actually kicks out the ice is called a "rake"arm, and is actually part of the icemaker mold assembly .
If you click on the part number in my last post, You'll see the difference, if you click on the pictures near the bottom of the parts screen.
:cool: :cool: :cool:
Guest (4)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
