clays
#1 Posted : Tuesday, September 28, 2010 9:27:46 AM(UTC)
clays
Our DW is not cleaning or rinsing well. The arms appear to be free and clear. Inlet valve? Pump? Any help would be great - thanks
#2 Posted : Wednesday, September 29, 2010 4:01:31 AM(UTC)
Here is the parts breakdown.
Replacement parts for General Electric GSD5560G00SS Dishwasher | AppliancePartsPros.com
You did not mention any problem with drying so I am assuming that the water is heating up and the heater etc. are OK.
Remove the sump cover (center of tub) and check that there is not debris or something wrapped around the chopper. Be careful, there is often glass in the sump.
Check that the screen filter is OK.
Check that the holes in the washer arms are clear.
Often this is a low fill situation. Often you can hear this, the pump will make a growling sound because it is sucking in some air. It should fill to just under the heating element.
A quick way to check this is to add a couple quarts of hot water after each fill during a cycle and see if it does a better job. Just be careful not to overfill it.
If it is low fill the most common causes is a partially clogged filter screen on the input side of the water inlet valve. Remove the valve from the unit and check/clean the filter. Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
clays
#3 Posted : Sunday, October 3, 2010 8:58:17 AM(UTC)
clays
Found a ton of soap buildup on the screens. Cleaned everything and have good improvement. Am going to run a few times before getting into the filter screen on the inlet valve. Thanks for the advice!!!
GE Triton XL (Dishwasher Repair)
by engrguy 7/5/2017 7:06:55 AM(UTC)
GE Triton XL not fully draining (Dishwasher Repair)
by Frank58 5/12/2015 4:30:10 AM(UTC)
GE triton Dishwasher won't fully drain (Dishwasher Repair)
by Porter123 8/11/2014 12:15:53 PM(UTC)
GE Triton XL - Stuck on rinse cycle, drain pump runs constantly (Dishwasher Repair)
by str-il 5/16/2013 4:02:50 PM(UTC)
old GE Triton XL: easy to replace heating element?? (Dishwasher Repair)
by Paul_illinois 12/28/2012 10:06:53 AM(UTC)
GE Triton will not drain completely (Dishwasher Repair)
by gronk 11/18/2012 4:33:41 PM(UTC)
GE Triton Dishwasher does not wash/rinse (Dishwasher Repair)
by mosierap 4/9/2012 3:10:17 PM(UTC)
GE TRITON XL water starts into machine but never washes (Dishwasher Repair)
by NC dishwasherprob 2/24/2012 10:13:20 AM(UTC)
GE Triton Quiet Power III. Draining- though not the piston nut assembly (Dishwasher Repair)
by maxweenus 2/1/2012 4:03:12 PM(UTC)
GE Triton Dishwahers quits cycle (Dishwasher Repair)
by sseaner 8/18/2011 4:25:28 AM(UTC)
GE Triton XL Middle Spray Arm missing O-ring (Dishwasher Repair)
by Johan Stayple 5/11/2011 10:23:26 PM(UTC)
GE Triton XL water inlet valve trips breaker (Dishwasher Repair)
by ryanbdkane 3/10/2011 7:22:30 PM(UTC)
GE Triton soap dispenser still full (Dishwasher Repair)
by vinceseg 2/25/2011 2:15:17 AM(UTC)
GE Triton XL Dishwasher (Dishwasher Repair)
by Randye 2/23/2011 7:54:44 AM(UTC)
GE Triton XL will not drain (Dishwasher Repair)
by SisQ 2/22/2011 5:03:40 PM(UTC)
