I replaced the display part of my oven almost a year ago. It's started displaying error codes E6 and F2. The oven will work only when the error codes are displayed for a little while. Then it will shut off and the display will be blank. Then a little later the error codes will show up again. Do I need to replace the control panel or is there another part I can try? I noticed that you don't have the control panel in stock and they said you want be getting them in until 2011. I need it before then because the holidays are soon approaching. Thanks for your help!!!:) :)
Originally Posted by: mlindsey3418  I replaced the display part of my oven almost a year ago. It's started displaying error codes E6 and F2. The oven will work only when the error codes are displayed for a little while. Then it will shut off and the display will be blank. Then a little later the error codes will show up again. Do I need to replace the control panel or is there another part I can try? I noticed that you don't have the control panel in stock and they said you want be getting them in until 2011. I need it before then because the holidays are soon approaching. Thanks for your help!!!:) :) M, That particular failure code (F2 E6) indicates a failure in the touchpad assembly, or a communication error between the control and touchpad assembly. Part number: AP3131916
You may want to try cleaning the connector on the control board and the insertion end of the ribbon with alcohol or a contact cleaner, and insure the ribbon is set in the connector tightly. :) :) :)
