I have a leak in the back of my frig. I have cut off the water source and it has stopped and when I turn the water source back on. It appears to be the valve itself or the plastic hoses. It's very hot back there. My guess is it's the valve but I can't really figure it out. The valve is part # AP319262 it appears. But I'd hate to buy a new valve, install it and then the problem be elsewhere. Also, how difficult is the installation of the valve? Is it just cut the old hose and pop them in the new valve? I would appreciate any guidance here. :confused:
Originally Posted by: PAPIBO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a leak in the back of my frig. I have cut off the water source and it has stopped and when I turn the water source back on. It appears to be the valve itself or the plastic hoses. It's very hot back there. My guess is it's the valve but I can't really figure it out. The valve is part # AP319262 it appears. But I'd hate to buy a new valve, install it and then the problem be elsewhere. Also, how difficult is the installation of the valve? Is it just cut the old hose and pop them in the new valve? I would appreciate any guidance here. :confused: Papibo, Yes it could be a leaking valve, Part number: AP3192626
But, It's more likely to be a loose connection or a crack in the tubing You'll need to check that before replacing anything. There's a little bit more to replacing the fill valve than you stated, but you're on the right track. Good Luck, :cool: :cool: :cool:
Joe. Thanks for the reply. After several tests I have determined it is definitely the valve... I'll order one here and check back once I have it for any tips on installing it.
Originally Posted by: PAPIBO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe. Thanks for the reply. After several tests I have determined it is definitely the valve... I'll order one here and check back once I have it for any tips on installing it. Papibo, OK, Will be looking for your post. :cool: :cool: :cool:
I have received the part for the frig. Do I just cut the old hoses and then plug them into the new part as well as connect the connectors to the new part and then install it? Is it more complicated than that? It's part # AP319262.
Originally Posted by: PAPIBO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have received the part for the frig. Do I just cut the old hoses and then plug them into the new part as well as connect the connectors to the new part and then install it? Is it more complicated than that? It's part # AP319262. Papibo, I guess you mean the water valve AP3192626. Yes, you are correct. Cut the tubes, make sure they're cut straight and , clear any burrs, and inert the ends into the fittings as far in as they will go, tug out on them, lightly, to make sure they are locked in place. Your process is the same as mine, make all the connections, and then check for leaks , then mount the valve to the frame . You're doing great, :cool: :cool: :cool:
Thank you Joe App Team. Awesome. With shipping this repair was less than $47. Over a $200 savings... with some pride that I did it myself. :)
Originally Posted by: PAPIBO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you Joe App Team. Awesome. With shipping this repair was less than $47. Over a $200 savings... with some pride that I did it myself. :) Great, Contact the ApliancePartsPros Team anytime you need parts or assistance, We're always happy to help. Glad you feel good about repairing your machine. :D :D :D
