pokievogel
#1 Posted : Sunday, June 14, 2009 5:49:08 PM(UTC)
pokievogel
My refrigerator is leaking and had water/sometimes ice in the vegetable bin and when I pull out the bin there is also water in the bottom. I do not see a water pan under the refrigerator-in the rear or front. Water also is on the floor in front of the refrigerator.
Thanks Colleen[IMG]http://imdb.colleenvogel[/IMG]
woodchuckie
#2 Posted : Sunday, June 14, 2009 7:38:34 PM(UTC)
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
pokievogel
#3 Posted : Monday, June 15, 2009 9:04:02 AM(UTC)
pokievogel
Where do I find it ? I have no clue///Thanks
vetteman
#4 Posted : Monday, June 15, 2009 11:34:24 AM(UTC)
vetteman
Drain is likely plugged w ice. Drain is located in freezer section and disassembly of freezer section is required. I use hot water and follow up w high pressure gas to clean drain lines
leaking refrigerator and will not stop (Refrigerator & Freezer Repair)
by jsfriedmann 4/26/2022 7:08:17 AM(UTC)
Leaking refrigerator door (Refrigerator & Freezer Repair)
by jml004 11/10/2011 5:54:20 AM(UTC)
Leaking Refrigerator (Refrigerator & Freezer Repair)
by PAPIBO 9/27/2010 9:04:33 AM(UTC)
leaking refrigerator (Refrigerator & Freezer Repair)
by TSTUCKMAN 8/25/2010 5:51:19 AM(UTC)
by dougkail 11/15/2009 3:54:36 PM(UTC)
by DeBucket 9/3/2007 8:56:53 AM(UTC)
