gordo634
#1 Posted : Tuesday, July 22, 2008 5:45:05 AM(UTC)
gordo634
Oven takes a long time to ignite or doesn't ignite at all and then I start to smell gas. The ignitor glows but not bright white, more like reddish orange. I think the ignitor is bad but looking for a confirmation and are they hard to change out. Thanks!
abadfish66
#2 Posted : Tuesday, July 22, 2008 7:58:07 AM(UTC)
abadfish66
No they ar e not hard to change, if you want to be sure the ignitor is bad, get an ohm meter and check resistance of the ignitor. should be between 50-150 ohms, anything other than that it is bad.
Top Oven Will Not Ignite (Oven Repair (including Ranges and Cooktops))
by tdolecek 8/22/2013 11:46:26 AM(UTC)
by montville524 9/10/2012 7:01:58 AM(UTC)
Bosch oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Stan Twardowski 4/16/2012 5:57:48 AM(UTC)
OVEN WILL NOT IGNITE (but igniter glows) (Oven Repair (including Ranges and Cooktops))
by dennis728 2/7/2011 5:44:03 PM(UTC)
Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Tracy H 12/19/2010 4:30:33 PM(UTC)
top burners & oven will not ignite (Oven Repair (including Ranges and Cooktops))
by cortlandt32 10/22/2010 5:16:37 AM(UTC)
Oven will not ignite, but broiler does (Oven Repair (including Ranges and Cooktops))
by BillWat 3/28/2010 4:12:20 PM(UTC)
by weberce13 1/12/2010 8:31:07 AM(UTC)
Whirlpool gas range oven will not ignite (Oven Repair (including Ranges and Cooktops))
by kamzuk 1/2/2010 2:59:23 PM(UTC)
storm now oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bonnie32f 8/17/2009 6:48:24 AM(UTC)
by jake59 6/24/2009 9:23:46 AM(UTC)
Gas Range Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Clubogilvie@yahoo.com 3/26/2009 12:03:07 PM(UTC)
Whirlpool gas oven will not ignite (Oven Repair (including Ranges and Cooktops))
by adamerik 11/5/2008 2:34:26 PM(UTC)
Tappan 12-1863-10/03 Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by areamon 6/4/2008 12:36:22 PM(UTC)
Burners and oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bren 7/26/2007 12:32:27 PM(UTC)
