efudd
#1 Posted : Wednesday, September 22, 2010 3:22:25 PM(UTC)
efudd
Hi; my Amana ACS 3350AS has had a slightly temperamental touchpad ever since I've had it (for about 7 years). Now, when I turn the oven on, it will occasionally, after heating up, turn itself offcompletely, ie even the clock will reset itself. After some time (presumably after it has time to cool down), the clock will come back on displaying 1234 or 12 something). Today, however, it appeared to work fine (but I am obviously wondering whether or not it will act up during the holidays!)
Please help!
Thanks!!
#2 Posted : Wednesday, September 22, 2010 4:50:27 PM(UTC)
Most likely the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer and is no longer available.
Here are the breakdown diagrams and Replacement parts for AMANA ACS3350AS Range - S/c S/i Gas | AppliancePartsPros.com
efudd
#3 Posted : Wednesday, September 22, 2010 6:36:02 PM(UTC)
efudd
Thanks, Gene. Is there something cheap I could try before I end up buying a new oven? Like a thermostat or something?
Thanks!
#4 Posted : Wednesday, September 22, 2010 6:38:51 PM(UTC)
No, there is nothing else left.
You can try PCBR.BIZ. Maybe they can fix the old control board.
Gas smell after oven turns off (Oven Repair (including Ranges and Cooktops))
by Mtfalk64 2/17/2022 2:16:10 AM(UTC)
Oven turns off after it heats up (Oven Repair (including Ranges and Cooktops))
by Guest 4/10/2021 9:05:44 AM(UTC)
Thermador Double Oven - Top Oven turns off F5 and F7 (Oven Repair (including Ranges and Cooktops))
by MattLester 2/9/2015 12:11:39 PM(UTC)
GE Monogram double oven turns off when temperature changed (Oven Repair (including Ranges and Cooktops))
by mlovelace 12/25/2014 9:26:27 AM(UTC)
by mlevy770 6/19/2012 8:26:04 PM(UTC)
Thermador oven turns off when baking/broiling (Oven Repair (including Ranges and Cooktops))
by nolanfr12 8/24/2011 6:06:46 PM(UTC)
Oven turns off, then resets in middle of cooking (Oven Repair (including Ranges and Cooktops))
by bdsammon 9/10/2010 5:42:47 AM(UTC)
Oven turns off (Oven Repair (including Ranges and Cooktops))
by mtalbo 1/14/2010 9:42:09 AM(UTC)
Gas oven turns off -no error code -part help needed (Oven Repair (including Ranges and Cooktops))
by barbboy 9/18/2009 4:32:03 PM(UTC)
Range/Oven turns off (Oven Repair (including Ranges and Cooktops))
by bknelms 7/12/2009 10:28:11 AM(UTC)
Whirlpool Double Oven Turns Off Before Heating (Oven Repair (including Ranges and Cooktops))
by BlazeMiller 6/19/2009 2:10:10 PM(UTC)
F9 code Oven turns off,lock light turns on,door does not lock (Oven Repair (including Ranges and Cooktops))
by darling132 11/12/2008 11:53:40 AM(UTC)
amana elec wall oven turns off (Oven Repair (including Ranges and Cooktops))
by amana98 8/27/2008 6:45:05 AM(UTC)
GE Profile Convention Oven Turns Off When Preheating (Oven Repair (including Ranges and Cooktops))
by martys 1/22/2008 2:56:57 PM(UTC)
