washer wont advance past wash cycle. timer does not advance. motor does not run. if i manually advance timer, nothing happens.
what about the timer, does the lid need to be shut to drain the water or just to spin
The lid switch is a safety device. It would not let the washer to spin and /or drain with open lid. - The lid switch Part number: AP3100001
Sorry for the delay. You have to remove the washer cabinet. The instructions are attached to the reply. Gene.
you were right. bypassed the switch and it ran. thanks for help. will order part you listed.
navarre cajun
Originally Posted by: navarrecajun you were right. bypassed the switch and it ran. thanks for help. will order part you listed.
navarre cajun You are welcome. Keep us posted. Gene.
