jrevino
#1 Posted : 15 years ago
jrevino
washer wont advance past wash cycle. timer does not advance. motor does not run. if i manually advance timer, nothing happens.
magician59
#2 Posted : 15 years ago
magician59
Check the lid switch.
jrevino
#3 Posted : 15 years ago
jrevino
what about the timer, does the lid need to be shut to drain the water or just to spin
#4 Posted : 15 years ago
The lid switch is a safety device. It would not let the washer to spin and /or drain with open lid.
- The lid switch Part number: AP3100001
jrevino
#5 Posted : 15 years ago
jrevino
how do you get to it
#6 Posted : 15 years ago
Sorry for the delay.
You have to remove the washer cabinet. The instructions are attached to the reply.
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 51 time(s).
navarrecajun
#7 Posted : 14 years ago
navarrecajun
you were right. bypassed the switch and it ran. thanks for help. will order part you listed.
navarre cajun
#8 Posted : 14 years ago
navarre cajun
Whirlpool washer stops after wash cycle (Washer Repair)
by u71589 12 years ago
Washer stops after wash cycle (Washer Repair)
by stanwill 15 years ago
by john miller 17 years ago
