rhiller
#1 Posted : Tuesday, September 21, 2010 8:48:03 AM(UTC)
rhiller
My wall oven heats up properly, but often does not cycle on the heating elements again when the temperature drops after initially reaching the target temperature. When this happens, I have to wait for the oven to cool completely before I can get the heating elements on again. I have tried replacing the clock unit and the keypad to no avail. Does anybody have any idea of what the problem might be? Thanks for your help.
Joe / APP Team
#2 Posted : Tuesday, September 21, 2010 10:51:46 AM(UTC)
Joe / APP Team
R Hiller,
Did you or do you have any failure codes on the display ?
If not I would have to suspect the relay board is on the way out.
Or the oven temperature sensor is way out of range,at higher temps.
Part number: AP4284825
Part number: AP4009009
Good Luck,
rhiller
#3 Posted : Tuesday, September 21, 2010 10:58:55 AM(UTC)
rhiller
That's what I was thinking based on a similar problem reported here... thread "Amana oven problem". I will order a new relay board. How do I remove the old relay board and replace w/ new?
Joe / APP Team
#4 Posted : Tuesday, September 21, 2010 11:07:25 AM(UTC)
Joe / APP Team
You will need to remove the control panel assembly,
Thats not going to be a problem, you've done it before.
You'll be able to see and access/remove the relay board from there.
It's located on the back wall of the control area/oven top compartment,on the left side of the cooling fan.
*** Just make sure you turn the power off at the breakers first . ***
Good Luck,
rhiller
#5 Posted : Thursday, September 23, 2010 3:01:25 PM(UTC)
rhiller
Sho-nuff the relay board was the problem. Swapped it out, and the oven works like a charm. Thanks much for your help.
Joe / APP Team
#6 Posted : Friday, September 24, 2010 5:17:26 AM(UTC)
Joe / APP Team
Rhiller,
Great job!!!!
And You're very welcome.
Thanks,
