doubledog
#1 Posted : Monday, September 20, 2010 8:59:09 AM(UTC)
doubledog
My dryer is only heating in the low[delicate] setting, whether it is on low or high. Is it likely the switch itself is bad, or the heating element is only working at 1/2 capacity, or other ideas? Any help, thanks.
bigger-hammer
#2 Posted : Monday, September 20, 2010 9:27:35 PM(UTC)
bigger-hammer
Youre going to have to take the drum out and take a peek at the element. Probably the element has broken and is grounding out on the chassis giving you only a little bit of heat. Not enough of a short to blow the breaker. Another common one is a metal bra wire has worked its way through the holes of the drum and gets caught on the element shorting half of it out causing the same symptom.
#3 Posted : Tuesday, September 21, 2010 3:12:42 AM(UTC)
Replacement parts for FRIGIDAIRE FEX831CS0 Frigidaire/laundry Center | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/1341356aelec_sheet_1.pdf
Yes the Fabric Select switch could be shot (contacts welded together), this would keep the thermostat's heater always on and you will only get low heat.
Unplu the unit and one side of the switch and check that it opens/closes with a meter.
