I own a very expensive Whirlpool Gold Oven and the touch panel has stopped working.
Whirlpool wants me to pay them $80/hour to come in and diagnose the problem.
can you help me with this?? I Have a [FONT="]GW395LEPS00 and the serial number: XS1303302
Non of the buttons are working and the display reads PF. [/FONT]
I have the same problem agraywall. I have a Whirlpool Gold Model # GY398LXPS. My control panel has been erractic for the last few months. The current problem is that the off button for the oven will not work. Everything else is functional. I have been pulling out the drawer to pull the plug each time I need to turn it off.
Someone please help us!!
Many thanks!!
I wish only a couple buttons didn't work. I want to order the touch panel or the control module behind the buttons but I don't know which one to replace.
I might just order both and return the one that I don't need.
A couple weeks ago I contact Whirlpool and received absolutely no sympathy from them. I feel totally ripped off.
Ripped off is right. We upgraded to this range when we built our house. Huge mistake. Hopefully someone has an answer.
Hey, Bad news, I got same problem. May be some one call "Whirlpool" to raise the problem. Let's get all people has same problem togather. Note: **the electrical part can not return** from any suppilier.
agraywall,
Most likely the problem with your oven is a bad control panel. In order to provide the right part number I need the color of the control panel.
Mine is S00 - S Steel finish.
johnmou, Looks like the cause and the correction of the problem with your range are described in this Whirlpool service pointer. Gene.
