| » Oven won't turn off |
Model Number: GY398LXPS Brand: Whirlpool Age: 1 - 5 years
My Whirlpool Gold electric range/oven won't turn off. Specifically, the oven won't turn off. Everything else is functional. Is it a bad control board? If so, is this simple to replace.
What happens if you push the "cancel/off" button? Does oven heats up to a set temperature or it heats up "non stop"?
The model number you posted is incomplete. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
That's the problem. The "Cancel/Off" button doesn't work. All of the other controls work. I can set the temp. and hit start and it works fine. However, when I'm done, the cancel/off button won't turn the oven off. I have to unplug the whole unit.
Thanks |
Gene, I checked and the model # is correct as far as I can tell. Attached is a link to my oven. This is my model. Thanks for your help!!
Compare prices on Whirlpool GY398LXPS Electric Kitchen Range - Epinions.com |
Most likely the problem is a bad control panel. In order to provide the right part number I need the color of the control panel and last two digits of the model number (after "S").
__________________
| Display Modes | |
| Oven and Burners won't turn on | keithv | Oven Repair (including Ranges and Cooktops) | 5 | 12-03-2007 11:55 AM |
| Lower oven won't turn off | bthomas202 | Oven Repair (including Ranges and Cooktops) | 2 | 11-23-2007 07:16 AM |
| Oven won't turn on | jdayseidel | Oven Repair (including Ranges and Cooktops) | 4 | 11-21-2007 05:59 PM |
| oven will not turn off | lbrown | Oven Repair (including Ranges and Cooktops) | 0 | 10-24-2007 08:19 PM |
| Oven will not turn off | daugherr | Oven Repair (including Ranges and Cooktops) | 0 | 08-23-2007 05:15 AM |
