nuke911
#1 Posted : Wednesday, July 16, 2008 4:16:44 AM(UTC)
nuke911
Looking for info on Fault code F24
Thanks :confused:
#2 Posted : Wednesday, July 16, 2008 8:38:39 PM(UTC)
Can you be more specific on the problem?
What is the model number of the washer?
nuke911
#3 Posted : Friday, July 18, 2008 1:05:58 PM(UTC)
nuke911
the code F24 flashes on the LED display where the minutes show and the washers stops and only way to get it going is to turn it off it is a Model He2T 110.47561600
#4 Posted : Monday, July 21, 2008 12:13:57 PM(UTC)
nuke911,
The error code "F24" means "Water temperature sensor error".
The temperature sensor is a part of the heating element (#13 on the break down diagram) and you can access it from the back of the washer.
Perform troubleshooting as described in the tech sheet(pages 3 & 10).
- The part number for the heating element is AP3865677
nuke911
#5 Posted : Monday, July 21, 2008 4:38:05 PM(UTC)
nuke911
thank you for your help
