Hi I have a Norge # LWN203W that had been in storage for about 4 years it will not agitate I checked the water level control line and it had a hole in it I removed the bad section and re-connected everything still no agitating but if I blow on the line the machine start to agitate could the WLC switch be bad? Also the WLC line is now shorter would that make a diff? Thanks in advance C C
Originally Posted by: Hunter30 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi I have a Norge # LWN203W that had been in storage for about 4 years it will not agitate I checked the water level control line and it had a hole in it I removed the bad section and re-connected everything still no agitating but if I blow on the line the machine start to agitate could the WLC switch be bad? Also the WLC line is now shorter would that make a diff? Thanks in advance C C CC, First things first, Replace the air dome hose, Part number: AP4025726
The water level control is not the problem, at this point, if It agitates when you blew in it, the switch and wiring are OK. You could have a clog in the bellows or the bellows opening. (where the air dome attaches to the outer tub assembly). Repalce the hose and check the opening on the bellows and we'll go from there. Good Luck, :) :) :)
Originally Posted by: Hunter30 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks Will do Hunter, You still could have a bad water level switch. But you need to get that hose replaced and openning checked for safety reasons, more than anything else, That machine could overfill and flood the house, if left in the present condition. Have you run a tetst cycle, does the machine spin, can you hear the pump sucking air, does the water fill ? Drop us a line if you need more help, :cool: :cool: :cool:
Yes it fills and spins and drains with no problem I will replace the hose and check the opening THANKS
Originally Posted by: Hunter30 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Yes it fills and spins and drains with no problem I will replace the hose and check the opening THANKS Hunter, OK, great. Drop us a line, when you're done. :cool: :cool: :cool:
Changed the hose still doing the same thing blew back away from the pressure switch no restrictions connected the line back to the pressure switch and blew and it started agiating for as long as I blew on it. Let it run through all other cycles and it did fine but no agiation. Thanks in advance
Originally Posted by: Hunter30 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Changed the hose still doing the same thing blew back away from the pressure switch no restrictions connected the line back to the pressure switch and blew and it started agiating for as long as I blew on it. Let it run through all other cycles and it did fine but no agiation. Thanks in advance Hunter, As long as you're sure there are no air leaks on the new air dome tube, You're going to need the Water Level Switch. Ther must be a mechanical failure inside the switch. Part number: AP4025680
Good Luck, :) :cool: :)
Replaced the switch everything is working fine thanks for all of your help. C C
Originally Posted by: Hunter30 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Replaced the switch everything is working fine thanks for all of your help. C C C C, Glad to hear that, You're welcome, :) :) :)
