2 Pages<12
#11 Posted : Thursday, September 9, 2010 9:07:14 PM(UTC)
Alex,
Remove the drain hose from the garbage disposal and put it in a bucket. Run the drain cycle and see how it drains. Post the results.
alex63
#12 Posted : Thursday, September 9, 2010 9:20:20 PM(UTC)
alex63
Sorry I don't have a disposal Gene but will try it tomorrow. Thanks for replying. I did do that before I changed the pump assembly and really nothing came out. I then blew through the hose and water did come out in other end so I don't think there is a blockage.
impaidbyu
#13 Posted : Wednesday, October 15, 2014 3:36:15 AM(UTC)
impaidbyu
On the bottom of the pump there is a exit for the water to drain. I took that hose off and found a flapper valve that was sucked in somehow causing a clog. After removing said flapper valve my dishwasher works great.
Good luck I hope this helps........:)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Frigidaire Dishwasher won't drain, fill, motor not running (Dishwasher Repair)
by Foofer 3/3/2014 10:13:05 AM(UTC)
by angelwings1968 5/7/2012 12:14:14 PM(UTC)
Frigidaire dishwasher won't drain and is leaking water (Dishwasher Repair)
by SHS1988 11/1/2008 7:32:28 AM(UTC)
frigidaire dishwasher won't drain (Dishwasher Repair)
by crankytroll 10/30/2008 3:52:27 PM(UTC)
frigidaire dishwasher won't drain when hot (Dishwasher Repair)
by corporate download 9/22/2008 3:32:47 PM(UTC)
2 Pages<12
