Alex,
Remove the drain hose from the garbage disposal and put it in a bucket. Run the drain cycle and see how it drains. Post the results.
Sorry I don't have a disposal Gene but will try it tomorrow. Thanks for replying. I did do that before I changed the pump assembly and really nothing came out. I then blew through the hose and water did come out in other end so I don't think there is a blockage.
On the bottom of the pump there is a exit for the water to drain. I took that hose off and found a flapper valve that was sucked in somehow causing a clog. After removing said flapper valve my dishwasher works great. Good luck I hope this helps........:)
